0 members (),
91
Mod | | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | I am doing the metal work on my '52 3100 and I have been reading about the metal shrinking disk.
I think this would be very helpful has anyone used this?
Would you recommend it?
Where can I get one? | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | I have many hours invested in using a shrinking disc. It does work to shrink the high spots but I have found it to be very slow going. You would use the disc if you did not want to use any body filler. I bought mine from one of the members on the site listed below. I don't remember his name for sure (John Kelly ?) but questions on this site will bring a response from him. He has a web site with some good pictures of his excellent metal work. http://www.allshops.org/ Here he is www.ghiaspecialties.com | | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | Thanks ... I reached John via e-mail and he is still selling them.
From your experience would you just use body filler then waste the time trying to get it perfect? | | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | Thanks ... I reached John via e-mail and he is still selling them.
From your experience would you just use body filler then waste the time trying to get it perfect? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Sunchaser Tools I have never used one but I have seen one used by an expert panel-beater. He was able to do magical things with metal with this tool (and he could also pick, hammer, and shrink - without the tool). He preferred the Sunchaser Shrinking Disk to more traditional techniques. | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | I get the metal as perfect as I can without using the disc. I'm using body filler (All Metal). When I started I tried to get the metal perfect without using any filler. I'm glad I did that but it's just too time consuming. | | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | I was looking at the Sunchaser disk but you have to purchase the whole kit which isn't cheap.
Rusty46 ... can you explain "I'm using body filler (All Metal)"?
Does this literally mean that you are using All Metal(lead or something)? | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | All Metal is a brand of body filler that uses aluminum powder instead of talc. It dries harder and does not absorb moisture. It's also harder to work with and more expensive. Usually used in an area that may encounter moisture, possibly from the back side. Unnecessary in normal body work. You can make a shrinking disc from a stainless lid for a cooking pan. I think John Kelly has some information on his site. | | |
