1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#11820 02/20/2004 5:50 AM
HI Everyone,
A few weeks ago I started to hear this clankity clank sound from under the hood. I thought it was the waterpump bearing going out, but it was the pulley. It had cracked/split connecting all 4 bolt holes together making the middle section loose making the out part flap. It even started cracking up the one side too. :o I welded it up on the outer side, and was fine for a few days, but it started again. :rolleyes: I went to a few yards today before finding a pulley, I get home, and it's 3/8th shorter depth on it. What years, and engines can I get the waterpump puley from that will work on my '62 235? Also what causes the pulley to crack?
TIA,
David
My truck don't leak oil, it just marks its teritory.
I can't answer your question about replacements, but the failure is usually due to an overtightened belt. I would also bet the bearing on your water pump is on it's way out, too. They don't like too much side load.
Fred
52 3600
69 C-10
Check your email, I have an extra.
Paint & Body Shop moderator
I had this happen to my truck several years ago. I my search for a new pulley, I learned about a reinforcement washer that GM put under the pulleys to help stop cracks from developing. I put one on with the replacement pulley and have had no problems since. I'm not sure what year GMC started doing this but I have seen them on just about every year of truck over the years of junkyard explorations. They could have been added aftermarket by the dealer also.
It would be easy to make one. It's just a disc of flat steel with the edge beveled to nest inside the pulley's inside radius. I think they were about 3/16" thick.
Hope this helps.
"The Operation of GMC trucks is normally smooth and steady, with no loud rattling, knocking or unusual noises. A good driver will quickly become accustomed to driving a GMC truck and will get the feel of his vehicle regardless of his engineering knowledge."-TM10-1563
