3 members (ronsway, tclederman, 1 invisible),
115
Mod | | | Forums66 Topics128,162 Posts1,056,960 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2015 Posts: 19 New Guy | | New Guy Joined: Nov 2015 Posts: 19 | Anyone tell me what jets are in the 32/36 Carter Weber Carbs, i have recently purchased new from Langdon Stovebolts, i have asked the question to them but as yet they havent responded, anyone know here i can get the data from as my truck is running rich | | | | | Joined: Sep 2016 Posts: 19 New Guy | | New Guy Joined: Sep 2016 Posts: 19 | Jets are normally not the issue but they can be. IF so it would most likely be the primary jet that screws into the venture tower. But;have you checked your float adjustment? A high flow level can do it as well or a flow that is leaking filling up or a bad float seat? IF you back out your air adjustments is there any change? Its not something simple like a choke setting is it? | | |
