0 members (), 103 guests, and 4 robots.
Topics128,095
Posts1,056,494
Members48,444
#1169366 06/14/2016 8:59 AM
Anyone tell me what jets are in the 32/36 Carter Weber Carbs, i have recently purchased new from Langdon Stovebolts, i have asked the question to them but as yet they havent responded, anyone know here i can get the data from as my truck is running rich
I have no idea what jets are in my 32/36, but here is a link to a great source of info from Sharps40. He gives info on the jets in his 32/36.
http://67-72chevytrucks.com/vboard/showthread.php?t=614035
Jets are normally not the issue but they can be. IF so it would most likely be the primary jet that screws into the venture tower.
But;have you checked your float adjustment? A high flow level can do it as well or a flow that is leaking filling up or a bad float seat?
IF you back out your air adjustments is there any change? Its not something simple like a choke setting is it?
