1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#1181498 09/07/2016 8:13 AM
I am building a 283 for my 1-ton, and have a questions about my setup. I am running new TRW 60 over pistons with a set of (601 casting) 305 HO heads, Edelbrock intake and Carb. I'm stuck on what size cam I should put into it. I was originally going to use the factory power pack heads and a Crane #968711 blueprint 300hp Cam but soon found out from the shop my power pack heads were not economically repairable. Now I have the 305 HO heads I'm not sure this would be the best Cam for this setup and looking for a little advice. I am not trying to build a street rod but more of a weekend cruiser. I am using a SM465 4 speed and a 14 bolt rearend 3.73 gears if this helps any.
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
Blind1968 #1181530 09/07/2016 3:52 PM
H Online: Content
Check out the Comp Cams 268H cam and the appropriate installation kit- - - -valve springs, retainers, keepers, etc. If you choose to run a double-row timing chain, don't forget to use a thrust button so the cam doesn't "walk" back and forth and cause the ignition timing to fluctuate. I would always braze a big flat washer to the middle of the timing cover (on the outside) to prevent it from "oil canning" from the pressure of the thrust button.
Blind1968 #1181618 09/08/2016 2:51 AM
Thank you Hotrod, That's a fairly choppy 350 cam isn't it? Would that give me better performance over the 300 Hp 327 cam? Never thought about a thrust button for a Gen 1 small block but I see they do make them. I am using an aluminum Timing chain cover so I will not be able to reinforce it.
Blind1968 #1181638 09/08/2016 4:38 AM
H Online: Content
There's just a bit of idle lope, without needing to have a much higher than normal idle speed. I've used it successfully on several 350's in the 350-400 HP range on the dyno. It pulls strong from 1800 to about 7k RPM or a little more and starts building noticeable torque and acceleration above 2K. I had that cam in a 305 claimer engine on a 1/2 mile round track and outran some pretty well-built 350's. It will have a bit more of an idle lope in a 283 than with a bigger displacement engine.
Blind1968 #1181668 09/08/2016 3:35 PM
One more question. With the stock 305HO heads its my understanding they should just be a straight forward bolt on replacement without having to do any major modifications? Is there anything you can think of that might be an area of concern?
Blind1968 #1181674 09/08/2016 4:30 PM
H Online: Content
If they're the ones with the 58CC combustion chamber volume, they will have the same compression ratio as the 283 "power Pack" heads, which is about 9.5-10:1, I believe. That's premium fuel range, or at least mid-grade. They should bolt on without a problem, but don't use the 305 head gaskets. The gaskets might overlap the cylinders with the 3 7/8" 283 bore. Here's a handy cross reference chart that gives casting numbers and combustion chamber volumes of a bunch of small block heads.
http://www.enginelabs.com/news/quick-ref-small-block-chevy-cylinder-head-casting-numbers/
Blind1968 #1181754 09/09/2016 12:45 AM
GM part# 10105117 would be a good choice for a head gasket. It's designed for up to but not exceeding a 4" bore, and the compressed thickness is .028. Available at Summit for $21.50 each. John
Blind1968 #1181818 09/09/2016 4:38 PM
John,
Im using the felpro 1003 Performance Head Gasket.
