0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | What about the post of the (fuel and ammeter) gauges ...hitting the edge of the hole ...insulated front and back, but the edge of the hole remains exposed to the post
Kind of like the game of operation | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I've been working on meters and gauges for many years (my gig was instrumentation and process control). Unless it was boogered with , I don't remember your concern ever being a problem. The face is screwed to the movement and then it's usually screwed to the housing. Vehicle gauges are some of the toughest around due to the vibration they experience. Accuracy is another matter. If this is keeping you up at night I might try increasing the post holes in the back of the case. You could then slip an insulator of your choice over the post (tubing?). Then run an extra nut with a insulating washer (fish paper) below it down to the the insulator, the wire lug and lastly, your capture nut. . This is of course boogering with (see above).
| | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | Advanced Design for 1953 I guess...but would never pass muster today. I wonder how many of these works of art burnt on the side of the road. A small slice of shrink tube on the post will let me sleep better.
I also restore early 1900 GE fans....you would be amazed that 90% of the ones I have done, show signs of a violent short inside the base. I rubberized the inside of the base on restoration.
