| | | Forums66 Topics128,206 Posts1,057,440 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | I'm working away on my truck, and it looks like the shaft is pretty pitted up. I have another one from a different truck, but whoever took it out pounded it out from the frame side and beat up the threaded end. Does anyone out there sell replacements? I've looked at a couple vendors, but no luck. Advice?
Thanks!
| | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | You may be able to fix the threads with a thread repair file. It is a many-sided file with different pitches on each side. It allows you to work on 3-4 threads at a time, working around the circumference of the bolt. Carl
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | The Brake / Clutch shaft is not being reproduced. This is a rare part & very hard to find NOS. I bought this one GM NOS for my 1954 in 2010. photo@photobucket http://i669.photobucket.com/albums/...rake_Shaft_3683044_b%202_zpsm4knzgk1.jpgGM # 0.833 - GM # 3683044 is available GM NOS @ NOS Parts Source Olathe, Kansas phone: 913-220-5746 NOS Parts Source has ( 1 ) GM # 3683044 in stock George '54 3600 | | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | The guy mushroomed the end of the shaft pretty bad, but I do have a friend with the tap & die stuff around, so we will give it a try. Thanks for a great lead, George! I had a feeling it wasn't out there in the reproduction world.
Thanks, Guys!! | | |
