6 members (Peggy M, kades51, fonz8261, Otto Skorzeny, 55shaker, tclederman), 96 guests, and 1 robot.
Topics128,132
Posts1,056,386
Members48,441
In the 1958 Chevrolet Truck Shop Manual, on page 11-5 (Clutch-Diaphragm) Step No.3 in the left column states, "Hand crank the engine until "X" mark on flywheel is at the bottom".
Gonna ask this anyway, but does anyone know where to look for this "X"? I took a wire wheel on a drill and cleaned my flywheel down to shiny metal as best I could. During that process I never recall seeing an "X" on the surface.
If the flywheel has ever been refaced the X will be gone.
It is not that important any ways, unless you are using the original pressure plate.
My Blog
Don't know if its the original pressure plate or not. Been working on putting this truck back together a long, long time.
Ran the pressure plate through my bead blaster to clean it up and it now has a coat of gray primer on it.
Apparently the original equipment flywheels and pressure plates were bolted together and then balanced. It's very unlikely to find a clutch system that's survived for 60 years or more without being swapped out. Even if the flywheel X is still there, ignore it! You won't find a corresponding mark on the pressure plate.
Thanks Jerry. Moving forward with the clutch/pressure plate/flywheel assembly.
Happy Labor Day!
