| | | Forums66 Topics128,006 Posts1,055,271 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | I know how to check capacitor, but how do you check s condenser? Cap has two connection points, but the condenser only has the pigtail. I usually change it when I change points, but it would be nice to know for future reference. Thanks, John | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | as far as I know, you check it the same way as a capacitor, the case is the 2nd pin. | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Thanks Mike. That's what I thought, but it never hurts to ask. John | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Touch the pigtail with the + wire of a 12 volt battery and the case to the negative wire of the battery, then toss it to your friend who is not known to be violent. He will immediately indicate to you if it is functional. Carl
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | 12 volts won't do it, but a pulsating 100+ volts will. I used to charge up condensers with the distributor tester and leave them on a wooden workbench for my "curious" students to pick up! Jerry
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | A very crude way to check is to use a VOM (analog) meter on resistance. Use the upper scale of resistance as that's the 9 volt battery on a higher end meter like the 260. Just touch the leads to the pigtail and ground. The meter will go to zero quickly as it is drawing current from the meter battery. Just as quickly the needle will move to infinity or close to it as the condensor build up to the supplied meter voltage. Reverse the leads and do the same test. Yes it's a very crude test but if the condensor is shot you will see it. This test is for electrolytic caps which is what a condenser type is. If needing more a local radio shop my have a real capacitor checker and check it for you.
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | 12 volts won't do it, but a pulsating 100+ volts will. I used to charge up condensers with the distributor tester and leave them on a wooden workbench for my "curious" students to pick up! Jerry Thank you for the correct method for making new friends!
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | are condensers all the same or do they vary depending on Make of vehicle, engine, etc
just curious, I guess the local Flaps would under stand if you said you needed a condenser for a 52 chevy 235 engine Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I test condensers by installing one in a distributor. If the engine pops, backfires, stumbles, has no power under load or acceleration, then I assume that the condenser is bad. Keep installing new ones until one works.
>> Don't replace condensers when you install new points, even though that's the way that we were taught in the 50s / 60s. If it is working then keep it.
Condensers are going the way of the buggy whip. Fewer cars need them, so major manufacturers are farming them out to off shore companies with less quality control. At least that's the state of condensers for low volume vehicles ... like my '55 MG TF.
New condensers for my MG are often bad right out of the box. Some owners have modified their distributors to accept condensers for high volume 1970's vehicles like Chevrolets. I use a condenser for a 1978 Plymouth Arrow in my MG because it fits and it works.
Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | There are a number of different types of capacitors. Many are used in electronics which do thing like phase shift to start an electric motor and blocking a DC voltage while "passing" an AC one. Current leads voltage with a capacitor by 90 degrees. Inductors (coils) are just the opposite. The electrolytic capacitors is used in our case here as it has the capacity to store an electrical charge as Hotrod noted. They come with various values and voltages. I have read in old car manuals that by looking at the "spike" that forms on points you can tell if your cap value is wrong. The spike will form on one side or the other depending on the value. OK, school is dismissed.
