2 members (qside, Gray_Ghost), 65 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#118061 10/18/2005 1:29 PM
1 Offline
Does anyone have a color chart for the 1956 3800? I am looking for info on color code " 443 J :confused: "
#118062 10/18/2005 2:35 PM
pick your year and chevrolet - another place doesn't list 56, but does have 57 , same difference - you could also check any of the literature dealers and find an original set of color chips such as the 2nd one linked above
there is no color chart for different models, only years, and as I pointed out before, no 400 series codes for any TF year - in my experience the paint code is almost never found on the trucks trim tag, except in cases of special orders
#118063 10/18/2005 8:29 PM
what would you like to know? it comes up as maroon on my computer!
Bent Happy Haulin!
TWO 1963 GMC\'s -- A shortbox and a NAPCO!
#118064 10/18/2005 9:04 PM
1 Offline
Bent Happy,
I really appreciate that. I am new to this series and have a had a struggle finding this color information.
Is that info on your computer something that I can search on the Internet?
Are there any details on the color if I wanted to try to match it back to original?
#118065 10/18/2005 9:31 PM
hey there, you could try autocolor library,just type that into google to find it,then go from there.as far as matching it to the original,you have the code ,so what more do you need ,someone to mix it.take the code to a body shop,they can give it to ther supplier,and mix in in any type of paint you want.sounds simple right,cause it is!!!
or if you have a part of the truck with the original paint on it,shine it up ,take it to a body shop,some shops will have a color camera,if they do they can get you a formula that will be a very good match.dont forget to have a case of beer visable when asking these favours,friday's arond three would be best!!!!ha
Bent Happy Haulin!
#118066 10/19/2005 1:15 AM
Is there any evidence that the truck may have been two tone? My 56 dealer data book lists the paint option codes for model 3803 as 443 (no J) for the deluxe cab two tone option code. The paint codes are **-***** digit numbers and no maroon color available for 1956.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#118067 10/19/2005 2:20 AM
CODE 443 WAS INTRODUCED IN 1951 AS A MAROON/BURGANDY,AVALIBLE IN LAQUER,OR QUICK SET ENAMEL.THE YEAR OF THE VEHICLE IS NOT ALWAYS THE YEAR OF THE COLOR.COLOURS ARE CARRIED OVER FIVE ,TEN YEARS, DEPENDING ON THE MANUFACTUER.COLOR CHARTS SHOW THE COLORS DEVELOPED FOR THAT YEAR ,NOT THE COLORS FROM PREVIOUS YEARS.I GUESS THEY HAD TO USE UP ALL THAT OLD PAINT,ONCE AGAIN CHECK AUTOCOLOR LIBRARY
Bent Happy Haulin!
#118068 10/19/2005 3:54 AM
Bent - auto color library is one of the links I gave above - it doesn't list 56 [none from 48-56], but does have 57
I doubt much that the 443 listed in the 46-54 paint ID list for 51 [DUCO #28285638, DULUX#580 burgandy red] is what a 56 tag refers to, unless as I said, it was a special order - Bruce's reference shows it as a 2tone option, which says nothing about actual color
need to find some evidence of original color on the truck, and then track down a current color code that's close to the original, as no one seems to have modern formulas for the old Dupont paints [except maybe Bob Adler?] - I even had a paint man try to get some formula info from Dupont and other paint co's for the TF colors and they could not give an answer
#118069 10/19/2005 11:46 AM
1959 Taskmaster 31,
It looks like no one has a 1956 Chevrolet Truck Data Book or Restoration Guide with color names, codes, and combinations.
PPG has formulas for most old paints. They would need the make/name/year of the color (and a PPG/Ditzler code would be nice).
What is the color and/or color-combinations for your truck (to your eye)? Here is a list of Dupont colors/combinations for 1956. The 1955/56 color chips are also at that link. Note: the color chips are old and not correctly rendered on a PC screen; however, they might help you identify the color name(s).
Once you get the name, PPG could then help you (and maybe you can find someone at Dupont to help you).
Good luck,
Tim
#118070 10/19/2005 4:39 PM
RED58; IF THE CODE ISNT ON THE TAG THEN WERE IS IT.EVEN IF 443 IS A TWO TONE OPTION ,IT SHOWS IT AS A BURGANDY/SILVER COMBO.YES WE DO NEED EVIDENCE OF THE ORIG.COLOR,TASKMASTER TRY LOOKING BEHIND ONE OF THE GLASS RUBBERS,AND SEE WHAT YOU FIND, ONE MORE THING RED58 ;THOSE ARE B.C PLATES ON YOUR TRUCK ,AND WHAT LOOKS LIKE THE OCEAN IN THE BACKGROUND ,JUST HOW FAR NORTH OF THE 49 ARE YOU?
Bent Happy Haulin!
#118071 10/19/2005 5:00 PM
As per 1956 Dealer Data Book:
Numbers are for Dulux Enamels
Forest Green 93-59639
Ocean Green 93-72002 H
Regal Blue 93-58184
Crystal Blue 93-72889
Empire Blue 93-2528
Cardinal Red 93-58209 H
Jet Black 93-005
Golden Yellow 93-58199
Yukon Yellow 93-6578
Sand Beige 93-57821
Omaha Orange 93-082
Granite Gray 93-72890
Arabian Ivory 93-58186
Bombay Ivory 93-72961
Pure White 93-21667
And for Sedan Delivery:
India Ivory 2003
Harbor Blue 2247-H
Nassau Blue 2238
Sherwood Green 2245-H
Pinecrest Green 2239
Matador Red 2246-H
Onyx Black 44
Option Codes differ according to truck model and cab trim level.
Bruce
#118072 10/19/2005 5:40 PM
BENT - because of the limited list of standard colors selected for commercial vehicles each year, putting the paint code on the tag was wasted motion that most plants didn't bother with unless it was out of the ordinary - I've had/parted 9 TF trucks [CDN and US] and not one had a paint or trim code on the tag
as for location, you\'re not paying attention! - also posts are easier on the eyes if not all caps grin
#118073 10/19/2005 6:26 PM
red58 OK so I didnt go to your web site ,you got me nieghbour.remember we are trying to help who is it again? taskmaster.alright so codes were not used unless it was a special application,in this case it is,so pull back the moulding taskmaster and let's see what color it is!!
Bent Happy Haulin!
#118074 10/20/2005 1:30 AM
1 Offline
Bent and all other helpers, I checked it again, it is stamped clearly "443 J" on the bottom of the weight tag which is in the door jam. The serial number is higher up and a smaller rectangle tag.
I will look around under things and see what I can find as I know this one has had red paint since the factory paint job.
I will post on here what I find. Thanks again, you folks are great!
This one is a dually, is stamped as "8,800 GVW". Is it worth much? Had Hydromatic from factory, is now 4 speed shifter, and has a Chevy 350 small block with a 4 barrel carb.
He is asking $2,500.
#118075 10/21/2005 7:25 AM
Try this link and just choose year and model
www.autocolorlibrary.com
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#118076 10/21/2005 12:58 PM
1 Offline
Thanks for that link. For some reason, paint colors are missimg from 1948 until 1955. It shows 1947 and then skips to 1957.
My gut tells me that the "443 J" was a special color, maybe a company color for a regional or national company. Are there any Chevy truck paint experts out there that might recall this number? We are still trying to locate an area that we know would be original paint to see what it looked like, no luck yet.
