| | | Forums66 Topics128,167 Posts1,057,020 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 42 | I would like repaint my tailshaft housing and replace the gasket. I've unbolted the tailshaft housing, removed the rear oil seal and speedo gear.
When I pull the housing, the tailshaft wants to come along for the ride. I'm afraid if I pull too much, I'll run into trouble with my gears.
Is it possible to slide off the tailshaft housing without any further work?
Thanks much for any input. | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Look for a small sheet metal plate held on by two screws on the underside of the tailshaft housing. Under there, there's a big snap ring that engages a groove in the output shaft bearing. It requires a set of expanding snap ring pliers with flat tips to hold the ring expanded while you pull the housing off. If it's been there a long time, it might be a little stubborn. Jerry
| | | | | Joined: Dec 2011 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 42 | Hello Jerry, thanks for the reply. I took a look and a photo to show the housing. I don't have a sheet metal plate. I'm assuming I can slide the housing off the tailshaft, but for whatever reason, the tailshaft wants to come with the housing. Tailshaft Housing Scott. | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | On that transmission the tailshaft will not come off without disassembling the transmission. Once you have the two sections separated you can get to the snap ring if needed. You can replace the rear seal with the housing in place. Fred
| | | | | Joined: Dec 2011 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 42 | Hello Fred, I really appreciate the feedback. One last question... if I remove the snap ring for the bearing, will the tail housing come off? I've found that I can access the snap ring without disturbing the trans. Here's a photo. Snap Ring Thanks, Scott.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The housing will pull off once the snap ring is expanded, but you risk loosing the roller bearings at the front of the shaft if you pull the shaft back to much. 1/2" is likely to be to much. I would at the very least pull the side cover so you can watch to be sure the roller bearings do not fall out.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | It can be done as Dave stated. I always just take them apart as they generally need something anyway. It's probably a good time to check for wear on the syncro engagement ring and the shift forks. Common wear components. Fred
