6 members (Hotrod Lincoln, klhansen, UtahYork, Leo, Goach2, JoeDude), 131 guests, and 3 robots.
Topics128,185
Posts1,057,294
Members48,467
I've been searching but no luck. It's a 1954 3100 3sp on column. All stock. I have smaller wheels so the speedo is off. I'm trying to find speedo gears (if available) but I can't figure what trans model number. Thanks in advance.
Saginaw SM318
Thank you for the reply and info. Much appreciated.
Is it also called Muncie? I'm looking for speedo gears but only small plastic ones I find. I looked at the trans and after removing the speedo cable it looks like a metal nut in the trans, maybe a 19mm or bigger. I've seen that they sell the all metal ones that look like it but not finding in 22 tooth or a lil bigger.
Why don't you calculate the speed difference and install a ratio adaptor in the cable? They are on eBay all the time.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Moderated
Moderated
If im reading the speedometer chart right, it looks like the driven gear has 20 teeth and the drive gear on the universal joint has 7 teeth. The GM Herritage center is a great resource.
https://www.gmheritagecenter.com/docs/gm-heritage-archive/vehicle-information-kits/Chevrolet-Trucks/1954-Chevrolet-Truck.pdf
