5 members (1955 1 Series, rfs56trk, dt235sd, Cletus1950, Bill Hanlon), 130 guests, and 2 robots.
Topics128,128
Posts1,056,664
Members48,450
#1179195 08/22/2016 5:37 AM
Hey all! I got a 1955.2 GMC 2 ton. Had a 270 inline 6 and going to put in a 350 vortec V8. Would a crossmember from a catalog work? Or would someone have V8 motor mounts from an original Chevy V8 2 ton they would sell?
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
Big Bolt Forum Moderator
crossmember from a catalog should work, if your engine has the bolt holes on the front, you can get reproduction original style front mounts online (have seen them on Ebay).
I was thinking abouth that same swap today while driving my 58 2-ton to Eastern, Wa (Omak). to pick up another cab. Mine got a 327 put in it at some point in the past, it is a bit under powered I think, and only got about 7.5 mpg today. Would be interested in seeing what you get with a newer engine!
Mike
I have a 4L80E trans hooked up to the vortec. I think I might have to cut out the crossmember. But if that catalog V8 crossmember will work then I think I will just get that. I have a 1999 Isusu NPR HD that I got the motor from and axles. So I can have disk brakes, PS, PB, A/C and so on. The NPR had the same bolt pattern as the GMC. I will be swapping the axles this weekend. Are you running your stock trans?
Yep, other than the 327 in it, my drivetrain is all stock. I may end up with a Ranger overdrive in mine at some point.
http://www.high-impact.net/transmission_and_gear/rangeroverdrive.htm
Mike
What's the ranger over drive?
the link is in my post above. It goes between the bellbousing and tranny. Moves your tranny back 7". I am kind of leaning that route although it will probably be a ways down the road, after I figure out whether to rebuild the 327 or go with a bit more cubes. I may build a 350 but need to see what kind of RPM I'l be spinning. I like the shorter stroke of the 327 for spinning higher RPM but would like the longer stroke (torque) of a 350
Mike
Make sure you do not use your old wheels with the npr lug nuts. They are a ball seat and your wheels are taper seat. I switched the studs to an American thread so I could use the correct lug nuts.
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
Very interesting! Never seen one before!
I had not seen that before and saw it mentioned in another thread on this site.
Mike
I got a crossmember ordered . Should arrive this week. Should fit. Said its adjustable for different widths.
