| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I have just tried a rust remover that I think works pretty good. It is called "a must for rust". It smells like the "rust iradicator" that we used to remove rust stains from clothes when I worked in a drycleaner as a kid. It has an acid smell. I don't know which.
Anyway you spray this stuff on let it set, wire brush it and wipe off. If the rust is thin you see new clean metal. Where the rust is very thick the metal is now smooth and black.
Has anyone ever used a product like this? I just want to be sure if I prime and paint my frame the paint wont be blowing off down the road when I take my first drive.
RB53 | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | It probably is acid. Oxalic or phosphoric. There are many metal prep products that contain phosphoric acid. I used one recently when I painted the upper cab on my '65. It doesn't list any ingredients? -David | | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | the active ingredient is phosphoric acid
i have a bottle of the stuff too. it is good for light surace rust, but that is about it.
2003 ford lightning 1959 chevy 36
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Which is why you see maniacs cleaning things with Coke (or Pepsi). | | | | | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | Does this stuff cause embrittlement? I guess it has it's appropriate application in some places, but I would be careful. I think coke or pepsi would most likely taste better... | | |
