3 members (Roy Rodgers, Oswald, Brian Moore), 124 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#117879 10/07/2005 1:30 PM
Junior Member
Junior Member
I have about a dozen rust through holes about the size of a pencil eraser in the beltline of my '49 GMC cab. I've not found anyone making a beltline patch panel and the only body shop in my small town proposed using a bondo type material to repair the rusted out holes. Am I correct in thinking I should avoid this bondo type repair or has this material improved since I last used it in the 50's & '60's ?
Mike
'27 Chevy
'41 John Deere B
'49 GMC
#117880 10/07/2005 6:29 PM
I'm no expert but in my opinion, a cab that is that far gone is beyond repair. With that many holes outside the seam I doubt the rust inside the seam could ever be stopped.
Maybe an expert can prove me wrong.
#117881 10/16/2005 5:09 AM
i had a cab that was rusted under the windshield around the middle vent it was much easier to find a better cab then to think about fixing it the kiss of death!!!
#117882 10/16/2005 11:19 PM
Anonymous
Unregistered
Anonymous
Unregistered
Of the truck is just going to be a driver for you then I would suggest welding up the holes using some copper backing material, Grind them down and make do with what you have. It may not be perfect but it will look fine.
