2 members (Woodcmiami, Bill Hanlon), 100 guests, and 4 robots.
Topics128,113
Posts1,056,279
Members48,439
#1178598 08/17/2016 9:35 PM
I am going to be using a 1954 type fuel sender in my 1950 3100. What is the "Best" way to accomplish this upgrade? I have the new tank and sender already just need to determine the proper way to plumb it.
I'm using the original 216 and the only modification to the truck is to the brake system (dual circuit master cylinder and Bendix brakes front and rear).
Jackie
Did the 54 fuel tank have the outlet in the bottom like the 1950? If so, use it. Easier to plumb to than going inside the cab. Plug off the outlet on the sending unit if there is one and get it going.
Measure the length of tube you need, buy one from flaps and bend where needed.
I did this on my 52. I think the line went straight forward to the edge of the tank, bent 90 degrees down and out an existing hole. The over towards the frame rail and generally along the rail then 90 degrees over to the block and another 90 into the fuel pump. I just sealed off the old gravity feed hole in the tank by using a bolt.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
You could also put a draincock in the old hole in the bottom.
Place the normal foam/rubber seal between the tank and the floor, around that hole in the floor.
I just did that modification on my '49. I bent the new line at the top of the tank to reach the vertical indentation in the center of the tank in the front, sending it straight down to the floor just behind the seat base. I drilled a new hole in the floor because the original hole is not in line with the center indentation of the tank. A short soft line with with two female brake line fitting ends go from there to the line heading to the fuel pump.
Carl
V
V Offline
I also did this to my 49 3100. Works great. The stock 216 fuel pump has no problem pulling fuel up and out the top of the tank. Had to drill a new exit hole for the new fuel line to exit underneath the floorboard and found a new rubber grommet at either Lowes or Ace.
