| | | Forums66 Topics128,087 Posts1,056,119 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I am going to be using a 1954 type fuel sender in my 1950 3100. What is the "Best" way to accomplish this upgrade? I have the new tank and sender already just need to determine the proper way to plumb it.
I'm using the original 216 and the only modification to the truck is to the brake system (dual circuit master cylinder and Bendix brakes front and rear).
Jackie | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Did the 54 fuel tank have the outlet in the bottom like the 1950? If so, use it. Easier to plumb to than going inside the cab. Plug off the outlet on the sending unit if there is one and get it going. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Measure the length of tube you need, buy one from flaps and bend where needed. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I did this on my 52. I think the line went straight forward to the edge of the tank, bent 90 degrees down and out an existing hole. The over towards the frame rail and generally along the rail then 90 degrees over to the block and another 90 into the fuel pump. I just sealed off the old gravity feed hole in the tank by using a bolt.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You could also put a draincock in the old hole in the bottom.
Place the normal foam/rubber seal between the tank and the floor, around that hole in the floor. | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I just did that modification on my '49. I bent the new line at the top of the tank to reach the vertical indentation in the center of the tank in the front, sending it straight down to the floor just behind the seat base. I drilled a new hole in the floor because the original hole is not in line with the center indentation of the tank. A short soft line with with two female brake line fitting ends go from there to the line heading to the fuel pump. Carl
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I also did this to my 49 3100. Works great. The stock 216 fuel pump has no problem pulling fuel up and out the top of the tank. Had to drill a new exit hole for the new fuel line to exit underneath the floorboard and found a new rubber grommet at either Lowes or Ace. | | |
