3 members (Donf, rfs56trk, 1 invisible),
130
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | Hi guys I have the two small air cleaners on my 51 pickup. 235 dual intake. These are not the big old oil bath cleaners. I was at a car show this weekend and a guy was telling me I needed to soak the red metal mesh in my air cleaners with oil. I have not done this yet and would like to know if this is something I should be doing. Thanks Paul | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | It depends on what they were designed for. If they were designed to be oiled then by all means. If not you could ruin the filter elements by oiling them. More info is needed. "Two small air cleaners" is too generic.
| | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | Without seeing them, I don't know, but oil soaked foam filter flow very little compared to a dry element. A friend of mine swapped a K&N oil type filter on to his race car and lost about 30 hp. Dirt is suppose to stick to the oily surfaces. | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | Not sure how to describe the air cleaners ,about six inches in diameter they are from the 50's seems to have been a option rather than oil bath cleaners. They have a red wire mesh between cap and floor of cleaner assembly. Truck seems to run fine so far | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | Reasons for less power with K&N: 1. too much oil (but this will fix itself eventually, the excess will be drawn into the port) 2. too small (diameter X height) 3. the top is too close to the air horn
The CFM flow per inch of filter area is excellent.
If your filter has cloth or paper in it, don't use oil unless it says so. Metal mesh is always oiled if it's the only material used, some are designed to hold a thin layer on the bottom surface. I prefer single grade heavy oil, lighter stuff has a tendency to pass through the engine too quickly. | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Oil on a filter is used to trap fine dust. Oil on a foam element will stop water and mud. Paper filters stop dust. Depends on the filter. Any air filter that cuts horse power is too small(not tall enough or to small around(surface area is too small) Dust is an abrasive(not what you need to keep any engine alive) To oil or not...depends on the conditions(lots of dirt roads on your trek?) and the maker of the filter. K&N uses a non woven material. Lots of fibers, and air will pass well. The oil they use closes the random gaps that are in that kind of filter. Some paper filters will dissolve with oil. Not good. Mesh filters(like our oil bath types) last a long time, if you clean them once in a while.
Steve H
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Sounds like Wodniw5 has a pair of pancake air filters.
1959 3100 Apache Fleetside
| | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | Yes the small spark arrest or or pancake filters. I have been taking them off and just blowing them clean with air compressor. Yes it's the copper mesh | | |
