4 members (Lightholder's Dad, Gdads51, SNOYL, 1 invisible), 150 guests, and 3 robots.
Topics128,258
Posts1,058,329
Members48,485
#1178406 08/16/2016 1:19 PM
Hello Everyone!
I am needing help as to finding the vehicle number tags location on a 1939 Chevrolet COE cab. Thank you very much!
1938 Chevy 3/4-Ton
In the DITY Gallery
1938 Chevrolet 1.5-Ton
Gonna be a classic farm truck
In the DITY Gallery
My 39 1 1/2 ton (Rusty) came from factory as far as I can see with no vin plate on cowl or anywhere else on cab. Never a Vin plate riveted on cowl like it's supposed to.This rig was used by the Wa. State Forest service for hauling (2) horses into the back country.
Do you see any rivet holes on upper cowl left or right? If not, 39 COE may have come off the factory line headed to some state or federal position where they do it themselves is my guess. Is there anybody out there that really knows for sure? freddy
I have a 1939 Chev COE also. There are holes on the right side of the cowl/firewall under the hood. But I think they were for the weight capacity tag? My truck had no tags on the cab, just those holes. I have been told that in 1939 Chevy used the engine block No.s for ID, but I have not seen proof yet. My truck came with a bill of sale only. But I have not been down to the DMV to see what they will say yet? My COE now sits on a P30 frame & is going through a complete up-grade.
O, by the way, I'm not sure what they called the frame rails in 1939, but a P30 frame is (Identical). My 1980 Chevy stepvan P30 frame rails are "Identical" to the 39 rails. If I had wanted to keep my cab on the 10" pedestal it sat on originally, my cab would had fit perfectly. The steering was there. Master cylinder with hydraulic booster off the van fit perfect under the short COE hood & every thing worked, using the brake peddle off the van. The front axle width is good also. But now I have independent front-suspension with power steering, power brakes, disc brakes in the front, with less chance of fatigue/cracks in the frame.
Do you have any photos?
By the way, do you got an extra grill???
Or maybe know were I can find some rear PU-truck fenders, 1939ish???
Have a gooder
Darrell, W.L.
1939 Chevy COE tow truck/My Stubbed toe
1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation.
I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
