| | | Forums66 Topics128,052 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 13 New Guy | | New Guy Joined: Oct 2013 Posts: 13 | I have built a 53 3100. I have new fenders...probably from China. The buckets are original and in very good condition. AS I stand and look at it....the bucket/headlight assembly appears to be cocked...ie the lines on the bulb are not parallel to the floor....the line closest to the center of the bulb had a difference of 5/16" from one side of the bulb to the other side. Both headlights have the issue...one side is worse than the other. The fenders/hood are bolted in and fit well. Will there be headlight alignment issues?? thanks Sojo | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Provided all is assembled correctly there should not be any adjustment issues. Make sure the spring is there that is attached to the bucket and puts tension on the headlight as you use the adjustment screws to draw it into position.
....most body shops have the old headlight aiming tools and can do it as long as its on level ground. I had my trim rings off and my local body shop set/aimed my lights in 15 minutes...for free. Hope your as lucky. | | | | | Joined: Oct 2013 Posts: 13 New Guy | | New Guy Joined: Oct 2013 Posts: 13 | Chipmunk, are the horizontal lines in the bulb parallel to the ground or is the line slanted? Mine is properly installed.Thanks | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I just went out and looked at my 51 the lens lines are perfectly vertical and horizontal. I don't know if the buckets are left and right, I don't think so. The fenders are made to GM specs so I would suspect the buckets. To finish my reply, yes that would produce big adjustment issues and the high low beam would not work correctly.
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I don't know if the buckets are left and right, I don't think so. Might be worthwhile to swap the left and right buckets and see if they come out level. .
1951 Chevy Panel Truck
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | there is no left or right buckets on your year of truck. Provided the buckets are correct for the truck.One of the adjusting screws should be in the 9 oclock position on both fenders, [with you facing the headlight] The other adjusting screw shouls be at 12 oclock
| | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | Same here Sojo: I have the original fenders on my '53 3100 truck, and the sealed beam bulbs are just a tad rotated (both in the same direction) on both my headlights. It's most easily noticed by looking at the lines on the bulb face.....This does not, however, noticeably affect the beam alignment.
