2 members (klhansen, TUTS 59),
64
Mod | | | Forums66 Topics128,066 Posts1,055,873 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | I have a 56 chevy long bed. I am at the point of sandblasting the frame.(cab off) I am not sure if I should paint the frame or have it powdercoated. Can someone give a ballpark figure on what it would cost to powdercoat? Is there some kind of undercoating that could be applied? Kevin | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | You may want to consider POR-15, Zero Rust or some other similiar product.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Hey kevin, I just had the frame of my '40 sandblasted and powdercoated. Total cost was $350.00. Turned out great.
Neil 1940 GMC 1/2 Ton
| | | | | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | Neil Did you leave your axles and springs on or did you take them off? kevin | | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | I had mine blasted and powder coated for $275. Bare frame, no axles, springs, etc. Springs may be a good thing to powder coat, but they'd need to be taken apart and done one individually.
You'll love the end results.
Good Luck! | | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | I took absolutely everything off the frame, then disassembled, sandblasted, painted and reassembled my springs. I also had the front and rear axle/axle housing sandblasted and then painted. Paint is easier to touch up than powdercoating.
| | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Kevint, I'm at that point also. Everything (almost) is off the frame of my 52'. Went down to the local blast and coat. I'm looking at $550 for the frame. $200 for the rear with torque tube. Each brake drum is $25 if not masked. You then have them turned and that will remove the PC on the inside. Spindles are $70/pair. They do the inner fenders for $75/ea. I'm here in Southern California, so things might have an environmental fee attached. Sounds like the other guys got a bargin. But the thought of actually doing assembly and on something clean and new looking is almost unreal! A question to the others; is it absolutely necessary to prime with a rest inhibator before powder coating? | | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | I just got mine back from the PC shop and it looks awesome so if you are considering it it definitely worth it. Here are a few things I am doing different next time:
1. Make sure you do some research on the the powder coater some don't do all that great of a job.
2. After they sandblast the parts go look them over. Because there are rust pits and bends that are really noticable after the powdercoat goes on.
3. I have made 4 trips back to the pc shop cause I keep finding more parts that need done. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Rattletrap - powder coating is only done on absolutely bare metal, preferably very freshly sandblasted - no other coatings can be used or the powder doesn't stick
Bill | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Rattletrap 52 Have them mask w/ tape the inside surface so NO PAINT goes on the drum inside
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Since i'll have my drums turned, the PC will be cut away. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might keep in mind that part of the job of brake drums is heat dissapation - there is a reason that drums have no coating from the factory
Bill | | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | Another choice which I used on past projects would be DP-90 epoxy. You will still need to sand blast but it is darn near bullet proof. This also goes by the name chassis black. | | |
