4 members (1955 1 Series, Barney1951, Millenimech, 1 invisible), 79 guests, and 2 robots.
Topics128,032
Posts1,055,438
Members48,422
#117705 09/16/2005 2:41 PM
Apprentice
Apprentice
I have a 56 chevy long bed. I am at the point of sandblasting the frame.(cab off) I am not sure if I should paint the frame or have it powdercoated. Can someone give a ballpark figure on what it would cost to powdercoat? Is there some kind of undercoating that could be applied?
#117706 09/16/2005 3:27 PM
You may want to consider POR-15, Zero Rust or some other similiar product.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#117707 09/16/2005 5:53 PM
Hey kevin,
I just had the frame of my '40 sandblasted and powdercoated. Total cost was $350.00. Turned out great.
Neil
1940 GMC 1/2 Ton
#117708 09/16/2005 7:26 PM
Apprentice
Apprentice
Neil
Did you leave your axles and springs on or did you take them off?
kevin
#117709 09/23/2005 4:17 AM
I had mine blasted and powder coated for $275. Bare frame, no axles, springs, etc. Springs may be a good thing to powder coat, but they'd need to be taken apart and done one individually.
You'll love the end results.
Good Luck!
#117710 09/27/2005 8:07 PM
I took absolutely everything off the frame, then disassembled, sandblasted, painted and reassembled my springs. I also had the front and rear axle/axle housing sandblasted and then painted. Paint is easier to touch up than powdercoating.
Neil
1940 GMC 1/2 Ton
#117711 10/04/2005 1:25 AM
Kevint,
I'm at that point also. Everything (almost) is off the frame of my 52'. Went down to the local blast and coat. I'm looking at $550 for the frame. $200 for the rear with torque tube. Each brake drum is $25 if not masked. You then have them turned and that will remove the PC on the inside. Spindles are $70/pair. They do the inner fenders for $75/ea. I'm here in Southern California, so things might have an environmental fee attached. Sounds like the other guys got a bargin. But the thought of actually doing assembly and on something clean and new looking is almost unreal!
A question to the others; is it absolutely necessary to prime with a rest inhibator before powder coating?
#117712 10/04/2005 5:18 AM
I just got mine back from the PC shop and it looks awesome so if you are considering it it definitely worth it. Here are a few things I am doing different next time:
1. Make sure you do some research on the the powder coater some don't do all that great of a job.
2. After they sandblast the parts go look them over. Because there are rust pits and bends that are really noticable after the powdercoat goes on.
3. I have made 4 trips back to the pc shop cause I keep finding more parts that need done.
#117713 10/04/2005 5:41 AM
Rattletrap - powder coating is only done on absolutely bare metal, preferably very freshly sandblasted - no other coatings can be used or the powder doesn't stick
#117714 12/13/2005 3:58 PM
Rattletrap 52
Have them mask w/ tape the inside surface so NO PAINT goes on the drum inside
Jim & Caroline
#117715 12/13/2005 4:28 PM
Since i'll have my drums turned, the PC will be cut away.
#117716 12/13/2005 6:13 PM
might keep in mind that part of the job of brake drums is heat dissapation - there is a reason that drums have no coating from the factory
#117717 12/17/2005 1:21 AM
Another choice which I used on past projects would be DP-90 epoxy. You will still need to sand blast but it is darn near bullet proof. This also goes by the name chassis black.
