8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible),
57
Mod | | | Forums66 Topics128,075 Posts1,055,919 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 7 New Guy | | New Guy Joined: Sep 2005 Posts: 7 | Hello, Working on a 53 pickup. I was going to spray out some hard to reach areas of window tracks, door jams etc. with lacquer before sending truck to paint shop. If the lacquer has time to cure can it be sprayed over with modern enamels ?
Is it worth the work or am I asking for trouble? I am comfortable working with lacquers but have no experience with enamels.
Please advise.
Joe. A. | | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | Enamel can be sprayed over lacquer. I don't advise lacquer over enamel. It will lift & pucker.
Jim Sgrig | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | tyou can spray the laquer, ans piewagn is correct, however, have you at least considered acrylic enamel? with hardeners the new enamels are very easy to work with, have excellant curing time, and you can get a high gloss without the buffing that's necessary for straight laquer.
the cure time with acrylic isn't near as fast as with laquer, but it don't take days before ya can work with it either like the old stuff. oh yeah, the cost is reasonable too. (nothing is cheap anymore). | | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | I wanted to use lacquer on a truck I am now finishing, but could not find it. Do you know anyone who still has it available other than in small spray cans? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Our O-Reilley's auto parts main dist. store in Little Rock still has lacquer, they can mix most colors still(some are no longer avaliable). Supposedly when they bought out all the mom & pop stores & other smaller chains they put the old stock at the main store, therefore they still have lacquer there. Brian | | |
