Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 40 guests, and 2 robots.
Topics128,003
Posts1,055,244
Members48,418
#1176081 07/30/2016 4:01 AM
are there any products out there that can reproduce the textured finish on my dash in the '55? my '59 has this too, but I don't know of any products right off hand.
any leads are appreciated.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Materman #1176116 07/30/2016 3:10 PM
Could they be "Hammertone"? If so, you can find spray cans at the FLAPS. Sounds like your getting some work done. thumbs_up
Materman #1176194 07/31/2016 12:25 AM
Is it a textured paint, or a hurry-up-get-it-done-fast from-the-assembly line paint job? I have never seen an original 55 dash with the finish you are describing. I have seen a very original 55 dash, but it was smooth.
Carl
Materman #1176201 07/31/2016 1:00 AM
It doesn't quite look like a hammertone finish, kinda reminds me of a toad's skin, lol. It looks like a textured primer base that the charcoal grey paint is sprayed over top of, it ends right as the top of the dash transitions into what was the lighter colored portion of the dash, I think it was to keep the glare down some, but not sure.
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
Materman #1176264 07/31/2016 5:48 PM
I also have the textured finish on the dash of my '59 and would like to duplicate the finish when repainting.
Materman, if you find a solution please post the results so I can learn from your experience.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
Materman #1176266 07/31/2016 5:51 PM
show us a pix of what you have..
Redryder pix
My Hotrod
Materman #1176286 07/31/2016 9:45 PM
My 55 also has the toad skin look & feel.
A friend on his 56 had his painter replicate it by dribbling on a very thick heavy primer to create the small bloches.
When that dried he used a flat black to overcoat it.
It looks factory original!
The assumption it was done to reduce glare is probably correct.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
