7 members (Oswald, FAST55, Ponchogl, 2-Ton, Oldcaliforniakid, Hotrod Lincoln, Donf), 74 guests, and 2 robots.
Topics128,042
Posts1,055,519
Members48,424
#1175967 07/29/2016 4:39 PM
I have a 1954 Chevy Truck 3100 1/2 ton with a saginaw 4 speed. There will be times when I'm downshifting from 4th to 3rd and it wont want to go into gear until I've slowed down quite a bit(unless I double clutch which I've only been able to do once - can't seem to get it down). Anyway, could this possible be something as simple as just adding more transmission fluid which I will check again this weekend or is it something more serious e.g. synchros?
Does everyone suggest 90w transmission fluid?
Thanks for the time
Scott M.
scooter m. #1175970 07/29/2016 4:47 PM
Big Bolt Forum Moderator
yes, 90 wt. Does it grind or just acts like it is stuck? First thing I would do it verify it is not real low on gear oil. Then make sure your clutch is adjusted properly and disengaging all the way. (if the clutch is partially engaged, that can make it real hard to shift!)
Mike
69Cuda #1175977 07/29/2016 5:10 PM
No grinding.....just wont push in to gear. When it does finally slip in there is a bit of a noise but not really grinding.
Scott M.
