0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | My mind is running loose this morning, and I'm wondering about building another truck. I've always wanted an AD style and was thinking of using a 250 6 cyl instead of 235/261. I understand the side engine mounts would be needed, and the aluminum bell housing with the transmission (t5) with rear mount would be used. The question I need answered is, would the original clutch linkage still work with the later bell housing? Would the original cross member have to be removed?
I know I shouldn't let my mind wander unsupervised but it happens sometime. I now have a headache. Any helpful ideas would be accepted.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Oct 2012 Posts: 57 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 57 | i have used the later 230-292 engines in the art-deco and A/D body styles.. i used frt. mounts and cast iron bell housings with mounts, instead of the side mtr. and rear trans mounts .. i guess you can do it either way depending on the parts available | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I think the cast iron bell is a great choice. Readily available and affordable. You then have the choice of using either a bell crossmember support or a support under the T5. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Jay the cast iron bell has the mount for the cross member, but there are none around here, been in all the junk yards, on craigslist. In search of, will keep looking I guess.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | A cast iron bellhousing for a 59-61 V8 will fit, but the window for the throwout arm is on the passenger's side. It's designed for a hydraulic slave cylinder instead of mechanical clutch linkage. Jerry
