| | | Forums66 Topics128,080 Posts1,055,946 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Figure I am going to change the body mounts on my 49. Have the parts. When this is done does the body have to be braced on its own when the existing bolt/mount comes out? I plan on doing one bolt at a time. | | | | | Joined: Feb 2004 Posts: 9 Junior Member | | Junior Member Joined: Feb 2004 Posts: 9 | I assume you are talking about the rear cab mounts. I recently changed on my '47. I supported the cab with a hydraulic jack to keep the weight off the mount. I placed the jack towards the rear of the underside of the cab with wood blocking to distribute the weight. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Actually I was considering all the mounts. Is there something I am missing here? Thanks. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Bigmac54 regards to removing the shackle attaching brackets. I presume you undid the brackets on the frame and body and then removed the shackle unit to rebuild it off the truck. At first I thought I could do it on the truck but re-read my shop manual. However some people are telling me that it could cause more problems than it is worth to do it. Any comments? | | |
