3 members (Napco Man, dunfire, 68ironhead), 214 guests, and 2 robots.
Topics128,081
Posts1,055,955
Members48,430
#117577 08/30/2005 7:38 PM
Figure I am going to change the body mounts on my 49. Have the parts. When this is done does the body have to be braced on its own when the existing bolt/mount comes out? I plan on doing one bolt at a time.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#117578 08/30/2005 9:30 PM
Junior Member
Junior Member
I assume you are talking about the rear cab mounts. I recently changed on my '47. I supported the cab with a hydraulic jack to keep the weight off the mount. I placed the jack towards the rear of the underside of the cab with wood blocking to distribute the weight.
#117579 08/31/2005 4:54 AM
Actually I was considering all the mounts. Is there something I am missing here? Thanks.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#117580 09/09/2005 6:51 PM
Bigmac54 regards to removing the shackle attaching brackets. I presume you undid the brackets on the frame and body and then removed the shackle unit to rebuild it off the truck. At first I thought I could do it on the truck but re-read my shop manual. However some people are telling me that it could cause more problems than it is worth to do it. Any comments?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
