| | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Did our 47-53 trucks come stock with a fan shroud? Mine is a '53 GMC 1-ton with a Chevy 235 engine and does not have one, but if I sit in traffic in 90℉ heat it gets up to 215-ish℉ and doesnt seem happy.
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | I don't think that they did. Later models like my '59 didn't have shrouds with a 235 engine. V8 engines had them but the fan was farther away from the radiator with a V8. I don't have any experience with your truck model though. Old radiators are often partially clogged up. When I was younger, I had several old vehicles that ran hot in hot weather until I got the radiator rodded out.
Gene 1959 Apache
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Retarded ignition timing can have an effect on engine temp. What year 235? Water pump location and fan clearance could also be a problem.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | A fan shroud was installed on big trucks, this will retrofit to small trucks and is easy to install as it splits. Here are some pictures of the shroud it install on the same bolts as the radiator. I am unsure of the ordering or installation scheme, I have found four on 32 AD trucks, all identical and all on 2-tons. https://www.flickr.com/photos/advance-design_parts_co/10039269655/in/album-72157631868452754/ | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | As the locus of fan blade position sweeps closer to the top and bottom tanks (covering the entire core) the need for a shroud diminishes. If the fan sweep is not centered, or is significantly small than the core, hot air already behind the radiator will simply be recycled (rather than fresh air being pulled through the core). | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | According to the casting number the engine is a 1954 GM replacement engine. Brand new water pump and a stock fan. Stock radiator. The engine is mounted back tight against the firewall so there is some space between fan and radiator.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 1954 engine should use the high mount water pump. There will be a little more space between the fan and radiator with a Chevrolet engine in a GMC,but I have seen this swap work without heating problems. I would look closely at the timing, and radiator condition.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 |
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | When looking at Brad's picture of the big truck shroud, do not scoff at the diminutive design of it. It makes a huge difference in the airflow and cooling ability while sitting still. I put one on my '49 with a 350 in it and the fan now will suck the sheets through the key hole from the other side of the house (as they say). Carl
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | my 52 with the 235 had no shroud and it never got hot and I drove it daily, well I take that back, it almost got hot once when the harmonic pulley came off at 65 and I was trying to get off the hi-way... I was lucky, it dropped and hung up,only lost the belt and nothing hit the radiator.. had to have it towed home but I was ok with that.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Air management has 2 separate functions, divided by vehicle speed. Below 35-50 mph (roughly, depending on the shape of the nose and grill) the fan delivers most of the air, and works much better with a shroud. Above that speed the fan does nothing, all incoming air that reaches the grill opening passes through the radiator core regardless. | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Well I put in a brand new radiator and advanced the timing and it still creeps up to 220℉ on a hot muggy day outside. Its probably 90℉ and sunny. Any other ideas or just don't worry about it?
| | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Is the coolant boiling? Does the temp go down when the vehicle gets up to speed? If you can answer "No" and "Yes", respectively, don't sweat it. A 15 pound pressure cap will let the coolant go to 257 degrees before it boils. Just be sure to run a recovery tank so any coolant that pukes out will get drawn back into the radiator as the engine cools down. Jerry
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Thanks Jerry - it does not boil, but it only cools down when it sits at idle, and it goes down to about 210. It seems to run hottest at about 50 mph in overdrive.
| | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Check to see which way the fan is moving the air. If you happen to have a fan for a serpentine belt system and conventional belts it will be pushing against the air stream out on the road. If the fan is cancelling out the ram air, things will get hot in a hurry. Jerry
| | | | | Joined: Nov 2012 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 39 | I had a similar issue on a Ford 302 V8 one time. It turned out the cylinder head had a small lump on the mating surface that allowed exhaust gases to flow into the coolant. That was a huge pain to diagnose. After replacing every single cooling system component with upgraded parts I figured out what the problem really was.
Place a funnel in the radiator filler neck. Fill with coolant until it is in the funnel itself. Run the motor until the thermostat opens and look for any air bubbles coming up through the coolant. The test seemed a little weird, but sure enough I had big bubbles coming out of the radiator. Had the heads machined and the overheating problem disappeared.
Chad | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Thanks for the additional ideas. The fan seems to be pulling rather than pushing so I think thats ok.
Interesting idea on the head gasket. It does leak some oil out of the back of the head - who knows, maybe there is a leak.
