7 members (Peggy M, Hambone, 68ironhead, 2-Ton, TUTS 59, DaveV, msmall),
54
Mod | | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11755 08/07/2003 1:13 AM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Is it possible to rebuild a water pump on a 216 motor..short shaft..Is there such a thing as a rebuid kit..
1946 chevy 1/2 ton panel 1937 ford coupe | | |
#11756 08/07/2003 1:22 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Yes it is , I had mine done 6 mths ago , new shaft and bearing and seal . I can't help with a kit in Canada though . | | |
#11757 08/07/2003 7:23 PM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | If you can disassemble it your self you may be able to go to your local industrial bearing and seal supplier and get them there. Does anyone no if you have to replace the shaft if it looks to be in good shape??
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#11758 08/11/2003 10:47 PM | Joined: Oct 2002 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 69 | Originally posted by Brian Moore: local industrial bearing and seal supplier shape?? what the heck is one of those places ? you must live in a large city ? hmmm
Randy the easter wabbit ! -here to help fellow enthusiasts as best as possible  parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others, | | |
#11759 08/12/2003 2:31 PM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | Acually I don't. However years ago this area was heavy into manufacturing and it has been around for a while.
If you are careful with the disassembly you should be able to get some numbers off the bearing and seal. Then look up bearings in the yellow pages and make some calls. Good luck
