3 members (55shaker, Bill Hanlon, 1 invisible), 54 guests, and 3 robots.
Topics128,037
Posts1,055,463
Members48,422
#11755 08/07/2003 1:13 AM
Is it possible to rebuild a water pump on
a 216 motor..short shaft..Is there such a
thing as a rebuid kit..
1946 chevy 1/2 ton panel
1937 ford coupe
#11756 08/07/2003 1:22 AM
Yes it is , I had mine done 6 mths ago , new shaft and bearing and seal .
I can't help with a kit in Canada though .
#11757 08/07/2003 7:23 PM
If you can disassemble it your self you may be able to go to your local industrial bearing and seal supplier and get them there. Does anyone no if you have to replace the shaft if it looks to be in good shape??
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#11758 08/11/2003 10:47 PM
Quote
Originally posted by Brian Moore:
local industrial bearing and seal supplier shape??
what the heck is one of those places ? you must live in a large city ?
hmmm
Randy the easter wabbit !
-here to help fellow enthusiasts as best as possible grin
parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others,
#11759 08/12/2003 2:31 PM
Acually I don't. However years ago this area was heavy into manufacturing and it has been around for a while.
If you are careful with the disassembly you should be able to get some numbers off the bearing and seal. Then look up bearings in the yellow pages and make some calls. Good luck
Brian Moore
