2 members (Otto Skorzeny, joe apple), 64 guests, and 4 robots.
Topics128,089
Posts1,056,139
Members48,435
1 Offline
Not exactly a stoivebolt, but my 1931 Olds will start, run as long as it is primed, then quit. I
ve checked the fuel connection at the carb and the fuel pump is working. I can prime the engine with gas or starting fluid and it will fire right away, run a few seconds and stop. The car has not been run in approximately 18 months. I have replaced the rotor button, distributor cap and condenser. I am beginning to think I have a carb problem. The carb is a Stromberg DXR-2.
Any ideas?
Joe D.
Float probably stuck closing the fuel off. Tap lightly on the area closest to the needle/seat with a small hammer or the end of a screwdriver. Then try again. If it does not free up you will have to pull it down and clean it. Good luck.
1 Offline
Thanks, I have tried that, first with a screwdriver, then with a small brass hammer. "The Carburetor Shop" has kits listed. So, unless I hear more here, I guess I'll try that.
Joe D.
1 Offline
Martin:
You were right on! I think I was just too gentle the first time around. The carb body is cast iron so I gave it a decent smack with the brass hammer ane the car ran better. So I smacked it again and now it starts and runs fine.
Many thanks.
Joe D.
Yep, when in doubt, use Percussive Maintenance. grin
Don't you just love it when a plan comes together. Run some fuel system cleaner in the gas tank and drive
