0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 94 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 94 | Not exactly a stoivebolt, but my 1931 Olds will start, run as long as it is primed, then quit. I ve checked the fuel connection at the carb and the fuel pump is working. I can prime the engine with gas or starting fluid and it will fire right away, run a few seconds and stop. The car has not been run in approximately 18 months. I have replaced the rotor button, distributor cap and condenser. I am beginning to think I have a carb problem. The carb is a Stromberg DXR-2.
Any ideas?
Joe D. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Float probably stuck closing the fuel off. Tap lightly on the area closest to the needle/seat with a small hammer or the end of a screwdriver. Then try again. If it does not free up you will have to pull it down and clean it. Good luck.
| | | | | Joined: Aug 2005 Posts: 94 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 94 | Thanks, I have tried that, first with a screwdriver, then with a small brass hammer. "The Carburetor Shop" has kits listed. So, unless I hear more here, I guess I'll try that.
Joe D. | | | | | Joined: Aug 2005 Posts: 94 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 94 | Martin:
You were right on! I think I was just too gentle the first time around. The carb body is cast iron so I gave it a decent smack with the brass hammer ane the car ran better. So I smacked it again and now it starts and runs fine.
Many thanks.
Joe D. | | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | Yep, when in doubt, use Percussive Maintenance.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Don't you just love it when a plan comes together. Run some fuel system cleaner in the gas tank and
