| | | Forums66 Topics128,292 Posts1,058,593 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | I like Deve's PVC system that hooks up to vacumme port on the manifold and I like my vacumme wipers has anyone used a valve system whereby if it rains you turn off PVC and turn on wipers. Sound weird but what the heck ....I guess a vacumme fuel pump is a better option who makes a good one that's ethanol proof..although they do take up more space.....decisions. Thanks, Steve | | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | Can't answer your question, but vacuum wipers stop where they are when you try to pass someone... | | | | | Joined: Feb 2004 Posts: 29,958 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,958 | Run a double action fuel pump (vacuum booster) and you can probably do both, The booster takes over to run the wipers when the main manifold vacuum is low. Jerry
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I ran my Willys wagon with PCV valve and vacuum wipers. I'd go for it and add the double action fuel pump if needed. Make sure your wiper motor is lubed properly, as the seal going dry will make it a lot less efficient! (you probably already know that though!) | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | What's the best way to lube the wiper motor? Did you attatch both lines to a two port fitting? | | | | | Joined: Jul 2013 Posts: 160 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 160 | What's the best way to lube the wiper motor? Did you attatch both lines to a two port fitting? You can spray silicone in the inlet port while it's running ...or disassemble it and lube with Vaseline, etc. The line routing is tricky. I ran my wipers to the vacuum/fuel pump inlet side, which then goes to a tee at the manifold where it joins the PCV. I also have vacuum assist brakes so have another tee fitting to that. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I don't remember what I found the best to lube it with, sorry. It was a number of years ago. a light oil that won't gum up if I recall. Air tool oil I think is one of the things I used. | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | I used the tech tip from Dave on my 58. I run both wipers and pcv off the intake. My wiper motor was rebuilt by the wiper man and I use rain x . I hardly need the wipers with the rain x. | | | | | Joined: Feb 2004 Posts: 29,958 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,958 | Back in the dark ages, a lot of the little 6-ounce cans of Casite Tune-Up were used to clean and lube wiper motors. I haven't seen Casite in about 20 years but any lightweight tune-up oil should do. (Rislone, Wynn's, etc.) There is an inlet port hose nipple on the wiper motor that supplies the air to the vacuum motor. Attach a short piece of vacuum hose to the nipple and submerge it into the container of tune-up oil and run the wiper motor until the container is empty. It will be drawn into the intake manifold and clean the wiper speed control along the way. Then it gets pulled into the engine and cleans the valve guides! Jerry
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I like Deve's PVC system that hooks up to vacumme port on the manifold and I like my vacumme wipers has anyone used a valve system whereby if it rains you turn off PVC and turn on wipers. Sound weird but what the heck ....I guess a vacumme fuel pump is a better option who makes a good one that's ethanol proof..although they do take up more space.....decisions. Thanks, Steve I run a PCV setup on my 49 216 w/vacuum wipers with no problems running both. I tried 3 different PCV valves until I found the one that would work and also allow the wipers to work. I did a thread on it a yr or so ago that detailed the PCV's part number so you can do a search if interested. As posted, a reservoir and/or double acting pump will vastly improve the stock vacuum wiper system but I never tried either. I just adjust my driving habits when caught out in the rain. You end up letting off the gas quite a bit  | | |
