3 members (Bill Hanlon, FishinToms53, tesa), 110 guests, and 2 robots.
Topics128,087
Posts1,056,000
Members48,430
#117518 08/26/2005 10:37 PM
Apprentice
Apprentice
I wanted to put a right-hand outside mirror on my truck, so I ordered the parts for it. They arrived today, along with some other goodies (hello, unbroken window glass!)
The factory accessory instruction manual indicates that the inside "reinforcement" piece, which is a threaded block that goes behind the door skin, is part of the mirror accessory package. Before I pull all the interior trim off the door to find out if my door has one rattling around in there, I thought I'd check here: Was this actually included on all factory doors at some point, perhaps welded to the door frame, or is this something I'll need to find at a swap meet? I don't see it in reproduction being sold by the usual suspects.
The truck in question is a '59 3200. Thanks for any info.
Z
Z Offline
in my 64 there was a inner panel with the holes in it.i drilled the holes from the inside out.
Rhoten - in the pass door there should be the same sort of triangular stiffening panel spotted inside w/ the holes and weld-nuts where the mirror mounts - if it's not there look in the drivers door to see what's needed - nobody repros them as they usually were in there even if the factory didn't put the mirror on - you also likely won't find it at a swap, as who'd bother to cut it free from a scrapped door? grin easy enuff to fake if necessary
oh yeah - the accessory manual is talking of the extendable mirror that requires more than normal reinforcement
Apprentice
Apprentice
Great, thanks for the info people. I will pop off that interior trim to take a look!
I did the same on my 59 3800 which has the same doors. There is a panel in there and all you have to do is drill holes where the supporting panel is from the inside. Worked just fine and quite easy to do. And in fact, come to think of it, my passenger door came off a different truck - and probably a 55 - as the fastener holes were a bit smaller.
Ditto on my 56. I got a pattern with my mirror that I positioned on the door and the holes I drilled from the outside were dead on.
If your mirror is chromed, it was suggested to me that you put a layer of clear nail polish on the bolt and screw as they rust.
Larry Bear
55.5 Chevy 3100 Panel
Apprentice
Apprentice
Just to confirm, yup, I pulled the inside door trim off last night and checked it out. The skin is double-walled where the mirror goes, and the reinforcement has holes in it where the bolts need to go through.
I guess the accessories manual is referring to some other door skin.
Now, once I get my son off to day care, I'll get that mirror installed.
