| | | Forums66 Topics128,050 Posts1,055,753 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Hi just about to install front fenders on a 46 just wondering what others have done, would you run the welt between the fender extension and fender also or just between the outer and inner fender only Thx | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Do you have pictures? There was no welting on the 46. There was some material between the cab and fender. You can buy a rubber material or welting but to my knowledge it was not as OEM. I did not want the welting so I used fabric tape between the fenders and bed and cab to reduce squeaks. | | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Hello GWWirth thanks for the reply I have no pictures but it's the same truck as your s, I just like the look and was going to put it on not really concerned about being 100% originall | | |
