1 members (baldeagle),
37
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | I am just thinking, you hardly hear of a 235 with hot start issues.
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | indeed. the action of pushing in the "stomp" pedal engages the starter gear | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Ok Thanks Tomc,
So theoretically it should it be possible for I6 starter to be used in a V8 app. The stomp would need to be massaged to fit the V8 and V6 switch would be required?
I am just thinking, you hardly hear of a 235 with hot start issues. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I don't know if a 6 starter gear will mesh with an 8 flywheel. Other than that, if you could figure a way to mount the linkage, I suppose it could be done. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | A high compression V8 may have too much of a load for a 6 volt starter fed by a 12 volt battery to last very long.
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | That foot start linkage that mounts to the 235 bellhousing will not fit a V8 bellhousing.
1959 3100 Apache Fleetside
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | If you want to keep the appearance of the stomp starter, it's possible to floor-mount a pushbutton starter switch for a tractor and adapt the stomper pedal to it. It can be made to look almost original. The switch will energize the solenoid of the V8 starter. I think somebody wrote a tech tip on that some time ago. Jerry
