7 members (SmalltownTRKGuy, 52Carl, Ponchogl, GradyB, Otto Skorzeny, GRNHydra, 1 invisible), 76 guests, and 0 robots.
Topics128,080
Posts1,055,945
Members48,430
#11741 05/23/2004 4:31 PM
I'm in the process of installing a NAPCO set-up on my 57 Chevy 1/2 ton (everything is rebuilt after 18 months of slow progress. I'm interested if anybody with a Tri-Five truck is running 8 inch wide rims. I'm hoping to use 16 or 17 inch height rims with a total height of around 33". Ebay has some good buys, but I'm not sure about clearances. If someone has a formula/genral rules for maximum tire/wheel size, that would be great. By the way, if anyone needs a 57 chassis, springs (3/4 ton), rear (3/4 ton approximately 3.70ish) and a stock front end, the're free if you can pick them up within two weeks (Minnesota).
donz - 8" on the front will prolly be a problem - if not in backset, then w/ rubbing on the draglink - 16's should give ya the height w/ the right tires - my 700/15LT radials are 29"
I just bought some 16x6 8 lug rims that work great. I mounted 235/85 t16 tires on them. They have 4" of backspacing and don't hit my tire rod ends. I left the receipt at home so I will post tomorrow with part # and source.
#11744 05/28/2004 11:36 PM
Thanks for the info. It looks like 8 inch wide rims will be a problem & 6 inch will work. Is anybody running 7 inch wide rims?
#11745 06/01/2004 11:10 AM
Lee Offline
Does anyone know if this rear axle would be a good (meaning easy) candidate for a swap with a 55.1 1 ton? I live in St.Paul. Or even if just the pumpkin would swap.
55.1 3800
I
I Offline
Lee
I believe the 3/4 and 1 ton chevy and GMC third members are the same from sometime in the 40's to 1972.
Sidehill
Lee Offline
Donsz, Is that rear axle still available? I am very interested in it. Maybe if I got rid of that 5.12 gear ration I would be a little happier with my truck.
55.1 3800
Lee - the 3/4 and 1T punkins are interchangeable, but a 57 3/4T isn't "3.70ish", it's 4.57, which is the same as the stock TF 1T, so I'd expect your 55.1 1T to be the same - I think that's what your askin? the 1/2T is 3.90, but a different rear axle
Lee:
The rear axle is still available. It is not the original axle from a 57 truck. The person I bought the truck from said it was a seventies vintage rear axle. If you want come by on Friday or this weekend and look at it. If you want it, its yours.
Junior Member
Junior Member
Donsz;
I have a 57 3600 that I have been through the same process that you looking at. I changed the original 4:57 gears out to 1972 4:10; changed the original 4 speed tranny to a 1984 T-5; and put 16"x7" AWC aluminum wheels on it with 235x85x16 steel belted radials. The wheels were maybe the hardest to find, however the 4:10 rearend would certainly be a close second. It all fits and works great and I am turning 2300 rpm at 65 mph on the hiway. I have a 59 261 ci engine in it and we make several two and three hour trips a year in it with no problem. Here is alink that shows how the wheels look on the truck.
http://www.chevygmcofkc.org/Gallery/showphoto.php?photo=522&papass=&sort=1&thecat=500
57 Mike
57 Mike:
Great job on your truck! I like your wheels, I have been considering exactly that style wheel. I like the way they look on your truck, thanks.
