7 members (TexasJim50, 1955 1 Series, Stovebolt48, 32Fordpuchoptop, lumbersawyer, JW51, 1 invisible),
54
0
Mod | | | Forums66 Topics128,080 Posts1,055,946 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11741 05/23/2004 4:31 PM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I'm in the process of installing a NAPCO set-up on my 57 Chevy 1/2 ton (everything is rebuilt after 18 months of slow progress. I'm interested if anybody with a Tri-Five truck is running 8 inch wide rims. I'm hoping to use 16 or 17 inch height rims with a total height of around 33". Ebay has some good buys, but I'm not sure about clearances. If someone has a formula/genral rules for maximum tire/wheel size, that would be great. By the way, if anyone needs a 57 chassis, springs (3/4 ton), rear (3/4 ton approximately 3.70ish) and a stock front end, the're free if you can pick them up within two weeks (Minnesota). | | |
#11742 05/24/2004 3:35 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | donz - 8" on the front will prolly be a problem - if not in backset, then w/ rubbing on the draglink - 16's should give ya the height w/ the right tires - my 700/15LT radials are 29"
Bill | | |
#11743 05/24/2004 6:06 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | I just bought some 16x6 8 lug rims that work great. I mounted 235/85 t16 tires on them. They have 4" of backspacing and don't hit my tire rod ends. I left the receipt at home so I will post tomorrow with part # and source. | | |
#11744 05/28/2004 11:36 PM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Thanks for the info. It looks like 8 inch wide rims will be a problem & 6 inch will work. Is anybody running 7 inch wide rims? | | |
#11745 06/01/2004 11:10 AM | Joined: May 2001 Posts: 16 Member | | Member Joined: May 2001 Posts: 16 | Does anyone know if this rear axle would be a good (meaning easy) candidate for a swap with a 55.1 1 ton? I live in St.Paul. Or even if just the pumpkin would swap.
55.1 3800
#11746 06/02/2004 1:53 AM | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | Lee
I believe the 3/4 and 1 ton chevy and GMC third members are the same from sometime in the 40's to 1972.
Sidehill | | |
#11747 06/02/2004 5:30 AM | Joined: May 2001 Posts: 16 Member | | Member Joined: May 2001 Posts: 16 | Donsz, Is that rear axle still available? I am very interested in it. Maybe if I got rid of that 5.12 gear ration I would be a little happier with my truck.
55.1 3800
#11748 06/02/2004 6:21 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Lee - the 3/4 and 1T punkins are interchangeable, but a 57 3/4T isn't "3.70ish", it's 4.57, which is the same as the stock TF 1T, so I'd expect your 55.1 1T to be the same - I think that's what your askin? the 1/2T is 3.90, but a different rear axle
Bill | | |
#11749 06/02/2004 2:44 PM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Lee: The rear axle is still available. It is not the original axle from a 57 truck. The person I bought the truck from said it was a seventies vintage rear axle. If you want come by on Friday or this weekend and look at it. If you want it, its yours. | | |
#11750 06/02/2004 5:00 PM | Joined: Oct 2002 Posts: 10 Junior Member | | Junior Member Joined: Oct 2002 Posts: 10 | Donsz; I have a 57 3600 that I have been through the same process that you looking at. I changed the original 4:57 gears out to 1972 4:10; changed the original 4 speed tranny to a 1984 T-5; and put 16"x7" AWC aluminum wheels on it with 235x85x16 steel belted radials. The wheels were maybe the hardest to find, however the 4:10 rearend would certainly be a close second. It all fits and works great and I am turning 2300 rpm at 65 mph on the hiway. I have a 59 261 ci engine in it and we make several two and three hour trips a year in it with no problem. Here is alink that shows how the wheels look on the truck. http://www.chevygmcofkc.org/Gallery/showphoto.php?photo=522&papass=&sort=1&thecat=500 57 Mike | | |
#11751 06/02/2004 6:01 PM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | 57 Mike: Great job on your truck! I like your wheels, I have been considering exactly that style wheel. I like the way they look on your truck, thanks. | | |
