3 members (tesa, Hotrod Lincoln, Nick in Manitou), 169 guests, and 2 robots.
Topics128,088
Posts1,056,002
Members48,430
#1174040 07/15/2016 7:39 PM
I have had to have the head on my 51 gmc 270 rebuilt due to a valve failure. I am missing one of the parts to finish up putting it back together though. I am not sure what to call this part, either its the oil shield that sits on top of the valve spring or its called a valve spring retainer. I am not sure but both of these parts look identical to me. Either way, I am not sure where to find one of these little parts. The shop that rebuilt the head said he would have to have one of mine in hand to see if he had anymore laying around, but I've already got them all back on the engine. My contact at Oreilys couldn't come thru. Anybody know where I could pick one up ?
Thanks, Troy
Troy
1963 Chevy C60
Big Red Chevy
1951 GMC 453 Series 3-Ton Army Truck
DLBrooks
DLBrooks
I have a locked up 270 in a 59 GMC 1/2 ton that will be a spare parts engine. I have a lead on a running 302 that I plan on using. If you strike out let me know and show a pic of the part. I have not had the valve cover off it yet. They may move your post to parts wanted.
1959 GMC 100 Fleet
Follow in the DITY
Thank you very much for that offer... I will let you know how it comes out.
I appreciate that very much !
Troy
Troy
1963 Chevy C60
Big Red Chevy
I do not know GMC engines. Though on top of my Chevy stovebolt the valve spring there is a metal cap. Looks like a small hat with a very wide brim that sits on top of the valve stem end and covers the top of the valve spring. The rocker arm pushes down on this "hat" to open the valve.
This "hat" is the valve spring rotator. My first thought when guessing what it was called an oil shield just as you did.
The valve spring keepers and valve spring retainer sit underneath the valve spring rotator.
I think Kanter Auto Parts sells the valve spring rotator with a new spring. Jeffrey
Thanks Jeffrey, that is exactly what I need. I will try and track them down and give them a call.
Much appreciated !
Troy
Troy
1963 Chevy C60
Big Red Chevy
Striking out on finding a supplier for the valve spring retainer. Anybody got any idea's ?
Troy
1963 Chevy C60
Big Red Chevy
Crusing in the Passing Lane
I might have one, I'll look next week when I have some time. Going fishing.
Ed
Man, that is awesome, Ed. The fishing part and the truck part too smile
Troy
1963 Chevy C60
Big Red Chevy
Need: retainer OD. Exh. or Int. Stem OD. Is spring side of retainer flat or stepped, if stepped, dimensions please.
Ed
