7 members (Donf, Gdads51, cmayna, Otto Skorzeny, Forty9, Gray_Ghost, 1 invisible),
91
0
Mod | | | Forums66 Topics128,118 Posts1,056,307 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 41 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 41 | I am brand new to Stovebolt and need some help. I have a 1959 Chevy truck with a 3 speed manual overdrive transmission, 235 6 cyl engine. I know there are few, I haven't found any, original kickdown brackets but all I am looking for is what does the bracket(s) look like? I would appreciate someone posting a picture of the bracket(s) so I could begin fabricating them for my truck. If you have one on your 50s Chevy please take a moment and post a picture.
1959 Chevy Apache Stepside Truck | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | The (1955) factory assembly manual R.P.O. 315 sheet 2.00 shows the KD switch, brackets & other OD detail. The factory switch bracket mounts to the carburetor. The throttle rod is correct in Dave's pictures. Fred
| | | | | Joined: Jul 2016 Posts: 41 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 41 | Thanks Fred, will look in manual.
1959 Chevy Apache Stepside Truck | | | | | Joined: Jul 2016 Posts: 41 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 41 | Thanks Dave, the pictures are great and will go a long way to my fabrication process.
1959 Chevy Apache Stepside Truck | | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | I ended up fabricating both the linkage tab and bracket from a drawing that Fred sent me a few years ago. It works just fine, even if it's not the stock, spot-welded affair. It uses cable pinch brackets to attach to the linkage. Here are a few snapshots of the setup I made based on Fred's drawings: Bracket Set Another angle Yet another... Fabricated set Tab end Before the switch went on... -Jim
