4 members (DaveV, TUTS 59, Ponchogl, Gib70), 112 guests, and 3 robots.
Topics128,129
Posts1,056,361
Members48,441
I am brand new to Stovebolt and need some help. I have a 1959 Chevy truck with a 3 speed manual overdrive transmission, 235 6 cyl engine. I know there are few, I haven't found any, original kickdown brackets but all I am looking for is what does the bracket(s) look like? I would appreciate someone posting a picture of the bracket(s) so I could begin fabricating them for my truck. If you have one on your 50s Chevy please take a moment and post a picture.
1959 Chevy Apache Stepside Truck
My Blog
The (1955) factory assembly manual R.P.O. 315 sheet 2.00 shows the KD switch, brackets & other OD detail. The factory switch bracket mounts to the carburetor. The throttle rod is correct in Dave's pictures.
Fred
Thanks Fred, will look in manual.
Thanks Dave, the pictures are great and will go a long way to my fabrication process.
I ended up fabricating both the linkage tab and bracket from a drawing that Fred sent me a few years ago. It works just fine, even if it's not the stock, spot-welded affair. It uses cable pinch brackets to attach to the linkage.
Here are a few snapshots of the setup I made based on Fred's drawings:
Bracket Set
Another angle
Yet another...
Fabricated set
Tab end
Before the switch went on...
-Jim
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
