6 members (Napco Mark, TooMany2count, baldeagle, Wheelie, Stovebolt48, RaNfLaS), 71 guests, and 7 robots.
Topics128,021
Posts1,055,346
Members48,420
#1173893 07/14/2016 10:29 PM
I am just thinking, you hardly hear of a 235 with hot start issues.
indeed. the action of pushing in the "stomp" pedal engages the starter gear
Ok Thanks Tomc,
So theoretically it should it be possible for I6 starter to be used in a V8 app. The stomp would need to be massaged to fit the V8 and V6 switch would be required?
I don't know if a 6 starter gear will mesh with an 8 flywheel. Other than that, if you could figure a way to mount the linkage, I suppose it could be done.
A high compression V8 may have too much of a load for a 6 volt starter fed by a 12 volt battery to last very long.
That foot start linkage that mounts to the 235 bellhousing will not fit a V8 bellhousing.
1959 3100 Apache Fleetside
If you want to keep the appearance of the stomp starter, it's possible to floor-mount a pushbutton starter switch for a tractor and adapt the stomper pedal to it. It can be made to look almost original. The switch will energize the solenoid of the V8 starter. I think somebody wrote a tech tip on that some time ago.
I recall it being just a thread, and after seeing it I did some research on switch options and bought a starter switch at NAPA to do the same.
In my estimation NAPA number ST6 being the best option.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1139884/faux_stomp_starter.html
1952 Chevrolet 3800 pickup
---All pictures---
