1 members (keithfielder),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Hi guys, I have my air cleaners converted to just a dry filter and they work OK.. I want to refurb them and change the filter element with one that does not need to sit on the fiber insert which is just there to take up space...never seems to line up right when installed.
The new element I found will sit just on the bottom of the bowl w/o the riser, and the top comes down to about 1+ inch of the top of the bowl... Confused yet?
My question is: How much room need I allow between the lid and the bowl for enough air flow to reach the carbs..? | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | It depends I reckon - is the engine just going to sit on display and idle all day or are those 'carbs' situated on top of a 6-71 blower and a tricked-out 6 banger capable of 11k launches?
I'd say you probably need to allow at least a 3/4" gap all the way around - an inch wouldn't hurt.
1950 4100 - unrestored and driven weekly for almost no reason at all.
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Well, no...not a blown 49 3100, or tricked out six, but is a daily driver. I can make it an inch or so...no problem.. Thanks for your reply | | | | | Joined: Apr 2004 Posts: 5,090 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,090 | I'm not sure if this will help but when I saw "Oil Bath Cleaner," I remember that we had done a Tech Tip not that long ago. Maybe this will give you some help or you can at least follow the link where it was discussed. Peggy M
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The oil bath air cleaners had no more than an inch clearance around the non-breathing filter-element housing, which sucked air up through a smaller surface area at the bottom of the filter element.
You will be OK with an inch all around. | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Peggy
Thanks for that link. I found a filter element at Reibies..NAPA Gold Filter 2221 which is 4" tall and provides only about 1/4" air flow space between lid and bowl. I will either put a spacer of 1" or so on the bottom or top of the lid to creat at least 1" of air flow space.. The NAPA filter was only $15 or so and is washable...
My plan is to have the metal parts powder coated likely a silver darker than chrome...or maybe just stock black plus the decal...
I'm running dual two bbl progessive webers and with new valves and seats it runs really well. Thanks also for all your help, Tim. | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Guess I should have sprung for the KN as they are nearly 1/2" taller and I wouldn't need a spacer...drat  Could not load your pics Matt...Just my finicky machine I'm sure.. | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Got the parts back from powder coater yesterday...they look great. Since I have that taller filter element I only needed a slight bit of a spacer to raise the tops up to a level where enough air gets thru. Bought a 5" I.D. PVC pipe coupler from Home Depot and my buddy with a band saw sliced off some 1/4" pieces to raise it up to where I have 3/4" between top and bowl..Should work well. Decals ordered from Chev. of the 40's..
Will put these pic on Photobucket in a bit... | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Just was able to open your pics...Looks very nice ! Good work..;) | | |
