9 members (Peggy M, Otto Skorzeny, tclederman, Shade Baby, DadsFirstPickup, FAST55, Bucker, wilbur53, 1 invisible),
78
Mod | | | Forums66 Topics128,159 Posts1,056,900 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I looked through the posts but didnt see anything. Has anyone ever done power brakes on a 1-ton using stock mounting location for the master cylinder?
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Question #2, does the stock master cylinder have the 10-lb residual valve in it?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Answer #1, Yes, you can use more modern master cylinder and booster. Several vendors sell different kits and brackets to do this. The important thing is using a MC with the same bore size to the original. So the MC sold for the 1/2 ton guys is likely not suitable for a 1 ton. So you could go to your local auto parts store and source MC with the correct bore, and suitable booster too. Some of those brackets look better designed than others. I saw one from CPP a couple months ago and it looked pretty floppy. Answer #2, yes it does hold some residual pressure in the lines, likely about 10psi however it is not specified exactly how much. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0504.htm | | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | Does any one have part# for the booster & MC or a link to one that would work in a 1-ton with a manual trans?
| | | | | Joined: Aug 2011 Posts: 228 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 228 | Greetings. I installed a power brake booster kit and dual master cyl for my disc/drum brake application. I have a 1951 1 ton with 4 speed and a PTO ! This system fit with all of the above in the stock location with the stock pedals.I also bought a remote fill that is necessary.
Performance Online, SKU # BB2-T4755, $392
performanceonline.com 714-278-0098
Good luck, Mike | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 |
