| | | Forums66 Topics128,035 Posts1,055,570 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Due to the major increase in local drivers I am considering a front disc brake kit. I have the catalogs, seen the ads and so on and despite what is written is there a true bolt-on front wheel disc brake kit using the original 16" wheels? If so who sells it. They all claim bolt-on but from what I have been reading here in the Forums and elsewhere each so called bolt-on kit requires some modification or a change of wheels. Thanks | | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | Im in the process of putting disc brakes in my 53. Went for Scarebird as you will see down in Driveline. Yes I had to grind off about an eighth of an inch from the calliper to fit my 16inch wheels. There is a lot of meat on the calliper so didn't bother me. Trying to find a booster and dual master to fit is another problem. the tech people at various vendors are not overly helpful. If you have a manual transmission that can be a problem as well as the cross member. I have an automatic tranny so that is one problem out of the way, but even the rear cross member may have to be butchered. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Thanks Stan.
