6 members (55shaker, Uncles51, GRNHydra, Ponchogl, JW51, Forty9), 55 guests, and 5 robots.
Topics128,021
Posts1,055,349
Members48,420
#1173147 07/09/2016 7:10 PM
So, I have a chevy 51 COE with a 3500 rear axle, dually, 10lug, 5.25 ctr.
I am thinking about putting the single wide drag type mickey thompson wheels/tires on the back of the truck. I think they only come in 15 inch rims with 5 holes. is some type of adapter available or is this a possible thing to do? The front wheels are the 19.5 wheels(p30)
Chris
51chris #1173149 07/09/2016 7:35 PM
Get a wheel adaptor to take you up to 22.5", 10 lug, 11.25" bolt hole semi truck wheels and run the big Super Single tires!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
51chris #1173185 07/10/2016 12:14 AM
I'm not aware of an adapter from 10 lug on 7.25" circle to 10 lug semi truck pattern.
I'm sure you could have custom wide wheels made with whatever pattern you want.
1952 Chevrolet 3800 pickup
---All pictures---
51chris #1173192 07/10/2016 1:27 AM
Hi Grigg
I called detroit steel wheel a while ago. They would not do a custom bolt pattern as aI was looking at their wheels for the front.
You know of any company that will make a super single per say in a 19.5 ?
thanks
Chris
51chris #1173206 07/10/2016 3:14 AM
Try Rickson Wheel in MD.
And Wheels Now, I forget where they are.
I hesitate to recommend Stockton Wheel in CA, though some chance they are better than they have been in the past.
---All pictures---
51chris #1173243 07/10/2016 5:34 PM
I don't think wide base tires are made in anything but 22.5. Instead of messing with adapters, why not put in a modern axle with hub piloted hubs. Zero offset 14x22.5 wheels would give you about the right width or you can go with 2" offset. I use both. And there is a wide variety of ratios available.
