| | | Forums66 Topics128,175 Posts1,057,056 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 11 New Guy | | New Guy Joined: Oct 2014 Posts: 11 | Im going to rebuild a mid 70s 2 jet and adapt it to my 230 (2 into 1 adapter). The carb has #54 Jets in it. If anyone has done this swap can you recommend a good starting size for the Jets | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Carbking might help. I'd repost in the engine section. You'll get a lot more views and maybe your answer.
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Strangling the airflow with an adapter will kill any advantage the 2-barrel carb might give. It's like making a long-distance runner breathe through a soda straw duct taped into his nose! Jerry
