| | | Forums66 Topics128,087 Posts1,056,107 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 50 Member | | Member Joined: Jun 2005 Posts: 50 | I have the new window glass and the setting tape, just how is the tape installed? CD said in oil , but thats all they said, can anyone go further then that? Thanks again, Paul
PJP
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I brushed oil on both sides then installed, hand pressure or a rubber mallet used gently. ^The oil swells the tape to get a seal. Brian | | | | | Joined: Jun 2005 Posts: 50 Member | | Member Joined: Jun 2005 Posts: 50 | Thanks Brian, will do today.
PJP
| | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | According to the shop manual you should put the tape in dry, insert glass then soak the tape.
I put the tape in, slowly slide the glass in place, used a rubber mallet to get the glass to fit, remember to check periodically the glass depth when closed, you don't want to get the glass in to deep so you don't get a good seal when closed to the window frame.
After I had the glass where I wanted it, I used a rag and mineral spirits to soak the tape, then I trimmed the tape after is sat overnight.
Took me about 30 minutes per window on my 55.1.
Hope that helps, Chris
Chris 1955FirstSeries
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I soaked the tape in oil for a couple hours then installed it. After I put the glass in I set it all in front of a heat blower to dry it out. Worked just fine. | | |
