0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#117266 10/02/2005 8:11 PM
I have the new window glass and the setting tape, just how is the tape installed? CD said in oil , but thats all they said, can anyone go further then that? Thanks again, Paul
PJP
#117267 10/03/2005 1:18 PM
I brushed oil on both sides then installed, hand pressure or a rubber mallet used gently. ^The oil swells the tape to get a seal. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#117268 10/03/2005 1:34 PM
Thanks Brian, will do today.
PJP
#117269 10/03/2005 2:20 PM
According to the shop manual you should put the tape in dry, insert glass then soak the tape.
I put the tape in, slowly slide the glass in place, used a rubber mallet to get the glass to fit, remember to check periodically the glass depth when closed, you don't want to get the glass in to deep so you don't get a good seal when closed to the window frame.
After I had the glass where I wanted it, I used a rag and mineral spirits to soak the tape, then I trimmed the tape after is sat overnight.
Took me about 30 minutes per window on my 55.1.
Hope that helps,
Chris
Chris 1955FirstSeries
#117271 10/03/2005 6:11 PM
I soaked the tape in oil for a couple hours then installed it. After I put the glass in I set it all in front of a heat blower to dry it out. Worked just fine.
Larry Bear
55.5 Chevy 3100 Panel
